Brief Description: Bottom Fuselage Diagonals with BOO-BOO
Finished T-7 diagonals in the rear. Started on T-10 diagonals from front corner STA A to center of B. Something did not look exactly right. After several measurements and double checking, found front corner at STA A passenger side out 3/8". Must have marked outside of CL twice instead of both sides. Would have been a big Boo-Boo considering engine mount and all. Rechecked all measurements again. Moved longeron into correct dimension @ Station A (29" CL to CL). Re-fit "A" cross-tube.
