All but the two nose ribs that mount at the flap drive are now installed for both wings. Also the tip ribs are all riveted in location and the drive linkages are all drilled into location but I have to order the appropraite AN hardware to finish mounting them in the correct location. I started on the false spar and the 4 trailing edge ribs that go at the wing root.
