Brief Description: Nose Rib attach angles for flap drive connection
Made the attach angles for both spars that connect the nose rib to the spar at the flap drive locations. I wish I did this at the time of the rest of it now but I did not feel like I would be able to put it in the exact right spot. I have learned since then if I would have had it in the wrong spot by a 1/8 inch it would still be fine. Drilled the flap drive and aileron drive supports to the spars for both the left and right wings. I will prime the last few parts tomorrow.
