Greggs RV-4
Date:  1-12-2015
Number of Hours:  1.50
Brief Description:  Drilled upper firewall weldments to firewall and j
This evening I decided to try and get the firewall bolted to the jig. I got halfway there...
It is a pain to drill the engine/jig mount holes for the upper longeron weldments. It's easy to know WHERE they are drilled, as there are 3/16th tooling holes in the firewall to help you. The problem is, you are going through 3/16th holes in the stainless firewall, to 2 different pieces of 1/8th angle cut at a 45, (and the butt joint is smack in the middle of that 3/16th hole in the stainless) to a steel weldment. I WAS able to carefully get a centerpunch to take in the center of the tooling holes, and was ultimately able to slowly upsize drill bits until I got to 1/4" for mounting to the jig. These holes will be upsized and match drilled to 3/8" eventually for the engine mount.
At the end of the evening, both upper weldment holes were drilled, and the firewall upper half was bolted to the jig.
Ready to drill upper weldment holes
One hole located to jig!
Upper longeron weldments drilled to jig.
