Brief Description: Riveted lower inboard skin on RH wing
I started this morning by finishing up the fit of the access panel area. That area has been a challenge from the beginning. After everyone else got up, I could make noise, so I vacuumed out the inside of the wing. Then, the lower inboard skin was ready to go on for good. The center wing walk ribs are definately a challenge. I can reach to the rear spar, (with the tank off) but my arm is thicker than the space between those ribs. :) Anyway, I was able to completely rivet the skin, by myself, without using a single pull fastener. My "helper" was a couple of bungee cords hanging from the ceiling, to peel the skin back so I could reach in. Took a while, but it's all done. Looks great!
