Greggs RV-4
Date:  3-4-2012
Number of Hours:  3.00
Brief Description:  Started on access panel, and top skin
I started today by cutting out an access panel to cover the access hole in the bottom skin. A tedious chore to get a consistent radius/gap between the skin and panel. After I had it pretty close, I started on the top skin. I started with a 4'X12' sheet of 032", and cut it down to 112" by 28.5" (or so). I was by myself, so had to call the father in law over to help hold the skin up while I started drilling it to the spar flange at the rib intersections. Man, that one piece top skin looks COOL. I then looked through the bottom of the wing, (rear spar) and marked the center of the rib flanges, so that I could mark hole locations, and pilot drill the skins. (pre-punch the hard way). I then spent the rest of my time drilling about 450 holes. The skin is now ready to be reinstalled, and drilled to the skeleton.
Trial fitting the access panel
Top skin drilled to spar at rib junctions
Drilling pilot holes in the top skin for ribs.
