Brief Description: Starting to skin the horizontal stab.
I assembled the skeleton today. Took a pic, but it did not turn out at all. Here I am using cutout wedges to help hold down the skin. I was then able to get some holes drilled. The 2nd pic shows that I was able to drill the entire bottom of the left hand skin. I put a cleco in every hole to make sure everything stayed put, as there is quite a bit of pressure on the skin.
