Brief Description: Drilling, priming and assembling of HS rear spar.
Lots of work today. Polished the HS spar stiffeners and triple checked their fit inside the spar web. Drilled the stiffeners to the spar web. Removed clecos, and deburred all holes. Set up primer booth, and prepped the stiffener bars, and spar webs to be primed. Primed the aforementioned parts, and organized the shop, and other HS pieces while primer was curing. After primer was dry, I assembled the rear spar and began riveting.
