Located the remaining engine fittings. Went through the plans for engine section, added manifold pressure sensor to firewall. Put covers on wires, attached starter cable to relay. Attached most fittings to engine, having trouble geteting oil temp plug off. Need to buy a wrench tomorrow. Place and Aircraft Spruce order fo axel shim, tach cap, and OLC connectors for the EGT/CHT wires. Installed prop governor
