Picked up a 1" wrench and socket, was able tyo remove the oil temperature plug. Found torque values for the fluid fittings on fuel pump (23-24 ft/lb). Installed oil temperature probe (finger tight plus 135 degrees) Installed prop governor (oiled gasket, star plus nut, 19 ft/lbs). Fit standby alternator on and got all four nuts started. I'm hoping that oil filter removal will give me enough room to torque the lower left alternator nut. Finished countersinking the canopy.
