RV-6A - GBC
Date:  5-30-2016
Number of Hours:  7.00
Brief Description:  AFP - pump/filter/plumbing etc
Vacuumed the cabin, and all the tailcone, baggage & tunnel. Laid a bead of GE Silicone along the forward junction of the tail with the aft bulkhead of the baggage compartment. Need to drill a couple of small drains (per plans) for water that 'might' get inside.
Removed rear window and using a plexiglass bit enlarged the holes for thermal clearance. Backing strips provide the anchor for special window rivets. Prepared for final installation now.
Cleaned up the cabin, underseat pans, and sponged the floor, too. Started fitting all the plumbing together for the AFP components and wiring in the center console. Had to fabricate a spacer for the Andair fuel selection to be 'flush' with the mounts, and add a wiring guide & Adel clamp for going over the spar edges. (add pic)
Final - awaiting fasteners
under the covers
under the covers
