Installed the angles against the center floor supports and then attached the 'fuel system package' which includes the AFP pump, filter and flow control. Custom housing and modified support for the manual elevator trim clecoed.
Removed the canopy latching system and made adjustments in the pivot fasteners to relieve resistance and smooth the operation. Adjusted the jam-nuts to get a better closed tension. Added a bolt to increase spring tension on the latch security.
