Brief Description: AFP FI - Pump/Filter & fuel selector
Some engine FWF details, then some work on cabin wiring (routing and wrapping the harnesses from the FW area under the center console (tunnel) and thru the spar hole.
Had to unwrap everything involved and clean-up a couple of mis-routed wires so all the wires would reach the seats (ribs) and flap housing.
Then finally got to finalize the fit of the AFP FI custom tunnel cover for the FI Pump and Filter. The fuel selector is a tight space for the various brake and fuel lines, and the wiring harnesses that pass through.
Had to disassemble a couple of times for adjustments and also change the direction of 3 spar bolts that were 'reversed' - but this time moved the ribs enough to work it out.
