Newly configured AFP boost pump plumbing allows path to route and bend the tank feed lines easily.
Re-bend the selector to manifold 3/8th" line, then fabricated the angle mount for the filter. Drilled and clecoed the filter and pump mount to the plate. Good enough to tighten the clamps and ready to test fit.
Bend a new feed line from the left side of the fuselage (grommet) to the bottom of the selector housing. Then hand bend the tubing to tuck up next to the left gear tower.
Enlarged the hole to 7/8" for the AN fitting (6D) to fit into selector housing. Need to order more 3/8" soft AL tubing.
