Started working on the left gear/brake lines and fabricated a 1/4" AL loop around the left axle, connecting to a SS braided hose on the gear leg. Decided to remove the 'street hardware' in the gear leg and mount tower. In that step I discovered that I need to ream the hole to 5/16" and had not done it. Unfortunately the pull-reamer has insufficient room to PULL the reamer in either direction. Will have to get an angle-drill to do this. and may have to release tower mount to move it.
Revisited this configuration after inspecting the drawing carefully and adjusting the position of the hose. Sufficient length to reach brake fitting without tubing. (2.26.15)
