Fabricated a #6 AWG to the forest of tabs ground on FW, and two power cables. One #2 AWG cable from the battery positve to Master relay IN, and a #6 AWG from Master relay OUT to the VP-X power lug IN.
Master switch activates Master relay and power is available to the VP-X.
Drilled the hole in the FW plate for the 1/2" pass-thru for the #6 power cable to the VP-X, deburred and drilled corner holes. Will have to delay until the FW seal is applied (Red RTV?). Need to rivet in the FW plate but again need FW seal applied.
Added a #8 nutplate and used Adele clamps for the EMS cables, and installed edge grommets in the lightening holes of the equipment bay ribs.
