Brief Description: VP-X - more testing and adjustments
brought the ADAHRS and EMS to the bench and worked through the setup of the VP-X/Electric screen, under the ENGINE screen on the SkyView.
Had to put the charger on the battery when it was below 10.5 VDC and the SV EFIS starting rebooting itself.
Combined the VP-X Configurator on the laptop, and its view of the VP-X against the SV EFIS view, and status as each switch on the panel was activated. Found and adjusted a couple of incorrect assignments.
