RV-6A - GBC
Date:  6-27-2015
Brief Description:  Taxi Light - wiring
Picked up a local source generic LED off-road typ wide angle light. Used the mount for the DuckWorks halogen ... and added a bracket mount point and slightly enlarged the hole.
Fabricated a set of power wires to thread into the wing conduit, and Molex connector. The ground point will be 'local' on the wing outboard rib.
Need to add a reinforcement layer to the new bracket to stiffen it from flexing. The LED housing is relatively heavy - current draw is 1.4A. Will connect to the Landing Light VP-100 switch (no current reason to not run Landing and Taxi simultaneously with such low load.
New LED taxi light
New LED taxi light
Wired  light
Wired light
Mount point
Mount point
