RV-6A - GBC
Date: 5-21-2013
Number of Hours: 2.50
Brief Description: Dynon EMS - inventory & review
Received the Dynon EMS module and Probes for Lyc 4-cyl F/I engine today. Inventories and inspected the contents and found some small items missing from the Fuel Flow Transducer. The bag was split and I'll examine the packing material.
Probes for all four EGT, CHT, Oil Pressure, Oil Temp, and fuel pressure included, along with wiring harnesses for the Dynon Skyview interface. Transducer was optional. Also included are the various terminations for connection after the wiring is threaded and secured.
Received a nice piece of 1/2 x 1/8th inch copper stock, which I thought would be adequate for the master to starter relay, however, unless it is rolled to widen it, the hole required would not leave enough edge. Find a good roller, and double up the strap.
Spent some time on the rollbar to check fit (measurements) again, and then drill the other splice plate. No rush - will continue when fresh - tomorrow.
Picturre of EMS kit to follow
Copper bar - relays (not)
