RV-6A - GBC
Date: 11-24-2012
Number of Hours: 2.50
Manual Reference: VP-100 Install
Brief Description: VP-100, Bench Test -
After some initial misunderstanding about the minimum wires to be connected, we fired up the VP-100 power control center to do preliminary orientation.
A good friend and electronics wizard, fellow HAM operator, Ken McLeod assisted by reading through all the instructions. Then with a 12V light bulb and some lead wires, we experiemented with the VP-100 switch assignments.
Like many new adventures, the learning curve was initially steep, but after a few confusing false starts the light went ON, literally, and then the concepts started to make sense.
Next step will be a complete inventory of the aircraft's electrical components, down to the wire length, items, operations, and loads.
Scratched the surface and was impressed with the operation of the control panel.
Ken setting a switch
Ken programming the keyfob
