Wired two more LED holders for the right wingtip strobes, and sketched documentation on the wingtip wiring design. Need to secure barrier strips to wingtip fiberglass after inserting lighting recess. Barrier strips consolidate power and ground connections from the NAV and Strobe LEDs to the wing wire harnesses.
Wired the connections on the back of the Duckworks landing light for 'ground' (return) and power. Need to finalize insertion of 2nd wire in 'sleeve', add nutplate to wing rib. Thinking about painting the interior of the wing skin and light mount but not convinced that it would increase effective light output.
