RV-6A - GBC
Date: 6-14-2014
Number of Hours: 4.50
Brief Description: Cowl - Upper, Trim & Fit
Lots of re-iterative fit & trim, trim & fit, file, sand, and repeat.
Worked on edges, hinges, thickness, and alignment. Installed starter ring assembly, and prop/spinner, to check fit. This will be a real PITA to remove with the prop installed in the future. Filing some edges off the curved eyelets helps with fit, but with both top/bottom hinges on it will be more complex.
Aft edges, and side edges (top/bottom) are looking very close.
UPDATE: Decide to raise the aft end of the side hinges to be avoid a 'locking puzzle' that would result between the cowl hinge and the sides. (more later)
