First had to remove the RT edge cowl addition from 6.3.14 and re-apply the resin and fiberglass clothe. Was not setting up. Used a hotter mix, and worked better.
Worked on cowl hinge pin and alignment to be sure it could be inserted, and retained at this position. Next - need to drill hinge/cowl and add nutplate for tab.
Shipped SV Intercom/Radio to SteinAir for harness fabrication and testing.
Downloaded the RV-12 Electrical schematic for the Sky View system and the Autodesk TrueView (free viewer). Many good documentation techniques used, and a guide to some of the same components for mine.
