Drilled out the left bottom hinge, inserted the .032 spacer strip (primed & dimpled) and re-riveted. Then riveted the right bottom hinge with it's spacer.
Little more filing, adjusting, and repeating. Very small steps.
Added a few more clecoes to the side hinges. Filed areas around the inlets, prep for further tasks.
Passed the 1,500 hrs mark. 80% done, and 80% to go.
