Deburred, dimpled, and primed, and clecoed. Ready to rivet the right FW bottom hinge. Cut spacer for the left bottom hinge but will have to remove the rivets to add the spacer.
Measured and marked location for MAP sensor on the FW. Decided to install on the engine side of the FW.
Primed the remaining pieces for the aft left baffles.
