Added a custom 3/4" AL angle to the aft left panel to stiffen. In the absence of a called out bolt, this will add to a soft panel.
Attached a couple of bottom and side hinge clecoes on bottom cowl and evaluated fit. Curvature of fiberglass will require build-up to match shape of fuselage.
Added a .063 spacer in the aft left corner, and need to add 4" ring.
More trimming on the top cowl, and a few clecoes in the bottom to secure it.
