Roughed the fiberglass surfaces, and filed down the high spots to assure good adhesion of the epoxy. Laided on to layers of glass cloth and saturated with West Systems 105 epoxy.
Had not devised a way to hold the aft edge of the inlet against the inside of the cowl, and subsequently had to apply manual pressure as the epoxy set. [NOTE did solve this issue on the other inlet the next day.]
