Routed the green & blue SafeAir Pitot/AOA tubing under the pilot armrest and fabricated a guide bracket with grommets. Drilled the seat pan and inserted grommets. Inserted the tubing and through the underseat area to wing opening. (Tubing is almost 1" from rudder cable but will add some additional shielding.) This is behind the pilot seat and relaitively safe.)
Squeezed the two rivets for aileron brackets, with borrowed 4" jaw squeezer.
Other tasks; Rudder fairing ... blind rivets on nutplate strips.
