Brief Description: Starting Vibrator - Mount (& P-Lead)
Mounted the Halon extinguisher on the right side of the center console (dog house) Reachable by either occupant.
Finished added the doubler on the Left side of the FW, to attach the Starting Vibrator. Mounted the SV connectors down, (BO and IN). Will allow access to the electrical components (if necessary) on the top side. Did a quick function test on a spare battery (12V).
Fabricated a 2-conductor P-Lead harness for the Retard Breaker (Left Mag), with 1 Primary lead, and 1) Retard lead. --- ground the shield on both ends. Connected to the L and LR ignition switch posts.
Need to fabricate a 2 wire harness to the ignition switch (BO & IN) from the SV.
