Brief Description: Baffle - SCAT duct to oil cooler
Fabricated a duct for the 4" SCAT hose from the left baffle to the FW mounted oil cooler. Started with salvaged duct from another oil cooler which was smaller but used a 4" hose.
This design will allow ground adjustments to the baffle air flow by inserting plates into a slot between the baffle aft wall and the 4" duct. The channel will not be adjustable in the air, more seasonal in nature.
