Making the modifications to both left and right ramps and side panels to more correctly conform to width of inlet from cowl. Decided to make repairs to ramp using AS3-032 AL Sheet material instead of replacing the baffle kit parts.
Completed repairs, deburred, primed, assembled and riveted the front left assembly, which installs as a single component of the baffle system.
Moved on to the same steps for the right ramp and side panel. Cut new conical insert, and ramp section but did not finish further.
