Worked on several baffle components related to the inlets, the joint of the forward side panels and the inlet ramps.
Fabricated the angles to attach ramps to the panels behind spinner, bent the flange on the left panel under the ramp, and finally the conical corners. These are to approximate the curve of the fiberglass inlets.
