Fit, drilled, countersunk and clecoed on the Rt Side hinge to the firewall (removing after each hold on the sharp bend, and every 2nd hole on the flat to countersink for a better fit before preceding.)
Also deburred the forward skin at the edge of the firewall, following a 1/16"" trim on yesterday evening.
Test fit the cowl for new measurements to trim aft edge.
