Brief Description: Elevator trim - cable retention
Compliance with SB on the tack wend needed on both sides of the nut (on the weldment for the trim control cable). Had the tack weld added to the weldment locally. Replaced the trim tab cable bracket - need to find the clevis and cable seals.
Next task - adjust the cable on the nut and add locknut.
