RV-6A - GBC
Date:  12-23-2015
Number of Hours:  1.00
Brief Description:  HS Fairings
Removed the AP Roll servo from the seat rib area and torqued the four bolts to the servo mounting bracket. Then did the safety wiring for each pair of bolts.
Then realized that the over-center limiting bracket could not be installed with one of the wires. Had to cut off the wire, and test the limits. One end of the travel is already constrainted by the fuselage side, making the bracket semi-moot. The end of the bracket also interferes with re-installation of the roll servo between the ribs. Will have to modify the bracket.
Fabricated 4 alum backing strips for the HS fairings, and started to drill for the CS4.4 rivets. (Interrupted for a forgotten appointment.)
Cut AL backing strips
Limit bracket vs safetie
