Picked up a rattle-can of self-etching primer at the local auto-paint supply specialists store. Also, some sheets of wet/dry sandpaper and variety of Scrotchbrite pads.
Unable to locate 6" Scrotchbrite wheel for the grinder - having tried auto-paint, hardware, and welding shops. Will obviously have to get this one from Avery.
Think that some of the generic tools, such as snips, are available locally for reasonable prices and are the same Wiss tools available in RV-tool kits. Leads me to consider a review of the tool list and identify a few of those competitive tools and get them.
NOTE: The small evap cooler is marginally working for the garage in the AZ desert heat. The R-30 ceiling insulation has helped but the uninsulated metal garage door and masonry west wall do little to stop the heat. Working directly in front of the cooler is acceptable for short periods.
