RV-6A - GBC
Date: 8-12-2007
Number of Hours: 1.50
Brief Description: False spar - removed
Removed the control sticks, and the main gear mount brackets, after re-assigning the 'false spar' to a new location outside the cabin.
The F-604 bulkhead is cleared and ready for the wings to be installed. Ok, preliminary install for fitting the pieces together.
Plan to install the Lt wing, then the Rt. The ailerons, flaps, and fuel tanks will be removed from the wings for the installation. Then they'll all get re-installed again to make the proper fitting.
Now that the bulkhead is cleared, I'll install those platenuts for securing the 'removeable rib' and securing the control stick brackets. That will help in the future when the wings are removed for months of completing this airplane.
Will have to set the incident, angle of attack, trim aileron pushrods, set the flap links, mark the tubing locations, and other tasks. This is progress.
Main gear bracket
Gear brkts removed
Ready for wing spar
