Finalized the landing light lens, in the left wing LE. More micro and sanding on the wingtip aft topside contour and added two internal supports to both wingtips to add rigidity to topsides.
Finalized the taxi light lens in the right wing LE, but still need to strengthen the taxi light mount. Too much weight for the mount to support without changes.
More sanding on the right wingtip topside aft surface, and a little bit on the bottom cowl.
Added some spacers (washers) for two allen-head screws in nose fork, to keep tire from being damaged on the 'too long' threads. This is a large screw to support the nose gear pant bracket.
