Finished trimming 5/16" and reforming the flap 'nose' to relieve interference on Rt Wing - Step-up for spar root plate.
Continuing to check Trailing Edge alignment with wingtips. This is a fiberglass issue - TE is cantered to one side slightly, although the top surface of the wing tip is aligned with the top wing surface. May have to split the TE of the wingtip and re-align it, with lots of fiberglass work involved. Don't see alternative.
Finished putting the CR3212-4-6 CherryMax rivets into the repaired/modified flap brace on the step-up plate. Have to work on the Rt wing next.
