The foam that was damaged by the bondo had been cut out. New foam was cut to shape and sanded to the correct height.
A section of foam was cut out for Nick Ugolini's fuel probes. On the starboard side, it is located 10" foward of the center spar and 6.5" outboard of the longeron or 6" O/B of the outer skin prior to faring. A small channel was dremeled back to the longeron just forward of the center section spar by 2" for the cables.
On the port side, the probe is 9" forward of the C/S and 6.5" O/B of the longeron. It is 6" O/B of the skin prior to faring. The cable channel hole is 1.5" foward of the C/S.
