The cable entry point into the cabin is located at the same place I intended to place a removable electrical cable cover. I used this opportunity to make a foam mold out of urethane foam and layed up 1 BID over the foam using clear tape for release. I will need to form flanges when I can place it in the cabin.
The probe length for both sides was verified to be 7.375". The depth on the starboard side is 7.9" and on the port is 7.6".
After completing the wiring connections according to the instructions, the wiring was tested according to section 12 of the instructions. The Princeton electronic modules were connected and powered up with 12V. The initial calibration was completed indicating that the wiring was installed correctly.
