Brief Description: Install Outboard OD Baffle and Fuel Tubing
The top and bottom skins were made larger than necessary at the outboard area to allow trimming to fit the OD baffle. Both port and starboard sides were trimmed. The OD baffle had an opening cut into it for access in the future. Both port and starboard side OD baffles were floxed into place and clamped in place. A 2 BID tape was installed at the joint to the center section spar and the R57 nose section.
