Brief Description: Installing the Electric Nose Gear System
I received the Loctite and applied it to the bolts. The actuator was reinstalled. The nose was set up on a 5 gallon bucket and the nose strut dropped sufficiently to access the bolt on NG3. The actuator was extended manually and the AN4 bolt installed with a washer on each side with a lock nut. The gear was extended fully without any gear growling. Problem was resolved.
