Brief Description: Installing the Nose Lift Assembly
04/05/2008 I made the MKNG-5 plate and drilled the holes thru the MKNG-6A and the N1-L Strut and the MKNG-5. I trial fit all the MKNG-6A, strut and the electric drive with the bracket. The electric drive pivot bushings did not fit at first. The alodined surface has reduced the ID of the hole. I talked to Jack and he suggested to simply sand off the alodined surface. It fit after that. 04/07/2008 I floxed the MKNG-5 and the MKNG-6a and the NG-3 and NG4 onto the strut. 04/19/2008 I drilled the holes in the bracket for the gear actuator to match the holes in the NG30s.
