Brief Description: Glassing the outside of the Shoulder Support
09/04/2006 I cleaned up the shoulder support installation from yesterday. Sanded everything down in preparation of glassing the outside. I epoxied the 5"x5" 3 plys of BID and cut up to use as shoulder strap attachment hard points. 09/06/2006 I glassed the outside of the shoulder support and used BID tape in the corners. I peel ply'd all surfaces and then realized that I should have installed the 3 ply UNI strap supports. I will install them after cure. 09/07/2006 I glassed the 3 UNI strap supports for the shoulder strap attach points. The holes still need to be drilled out
