08/03/2006 I flipped the fuselage and set it on the saw horses using a folded up U-Haul blanket. I then cut out the canard location forward of F28. 08/06/2006 Cut out the templates A-A, B-B, C-C, and D-D for the top fuselage shape 08/07/2006 Formed the top fuselage according to the templates. I have a few holes to patch where the sanding was a little too aggressive :) There is also some voids in the attachment of the upper longeron that I need to fill with flox. Tommorrow 08/08/2006 Filled in the voids around the upper longerons.
