Michael's Cozy Web Site
Date:  12-29-2005
Number of Hours:  4.00
Manual Reference:  Step 3
Brief Description:  Contouring the Inside
12/29/2005 I used a router to carve out the control stick depression and the fuel gauge. The pilot side control stick was inadvertantly made about 9" in diameter rather than the 8" specified in the plans. I do not believe it will affect anything
12/30/2005 Preped the co-pilot side by sanding with 100 grit
12/31/2005 Routed a corner on the longeron in preparation for glassing, prepared table for glassing.
FS Inside foam Contour from aft
FS Inside foam Contour from the front
