The electrical system has been documented on a set of drawings that will detail all components, wiring, and locations.
The primary circuit protection will be provided by the Vertical Power Electronic Circuit Breaker system. It is installed above the battery on the inside firewall above the spar. The battery is connected to a master solenoid. The solenoid connects to a starter solenoid and the amp shunt. The amp shunt is set up to measure the current charging and discharging the battery. The other side of the smp shunt is connected to the alternator B Lead, the vertical power, the E-Bus fuse block and the E-Bus circuit breakers.
