While preparing for painting, I accidentally knocked the landing gear cover off of the bottom and it hit the leading edge. The landing gear cover was not damaged; however, there was a hole punctured into the leading edge on the starboard side. The damage was cut out, a piece of foam fashioned to fit and it was epoxied in place. Two UNI layers were layed up at angles consistent with the original layup. It was all peel plied.
