Michael's Cozy Web Site
Date:  1-10-2021
Number of Hours:  3.00
Manual Reference:  Step 4
Brief Description:  Exhaust System.
The exhaust pipes are the Hal Hunt inside cowl design. Due to the arrangement of the pipes, it is very difficult to reach the back exhaust flange nut on cylinder 1; therefore, I took the pipes off of the slip joint. I then torqued the exhaust flange with the appropriate copper envelope gasket to 15 ft-lbs.
Then the fun begain. I could not get the pipes to go back onto the slip joint. I tried using heat, I tried brute force, nothing worked. Del Shier on the mailing list suggested using a tubing expander. I acquired one from Harbor Aviation Freight Tools and expanded the tubing slightly. I finally got it back on, then I had to get the springs back on, whew!
I installed all of the other pipes and torqued then with the copper gasket. I also drilled the holes for the EGT probes.
Before installing 2 and 4 cylinder, I finished connecting the oil drain tube from Cylinder 2 head drain.
I also installed the Gates V-Belt 7315 belt on the alternator.
